Improvements to Onshape - December 16, 2015
Onshape was recently updated and this will be the first of many releases without the BETA label. Last week we announced the commercial version of Onshape along with our private BETA launch of the App Store. A few statistics from our Beta program:
Here are some additional highlights of the recent update:
Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
- Over 10,000 users participated
- 400,000 hours of modeling performed
- 4,000,0000 model features created
- Imported/Exported 390,000 files
- Created 325,000 STL files
- Simulation
- CAM
- Rendering
- Content
- Design
- Import/Export
- Productivity
- 3D Printing
- NEW Replicate - Automated mate utility in Onshape Assemblies to copy and populate components.
https://youtu.be/SFPQ3Whso50
- NEW Detail View envelope - Fully associative detail view.
https://youtu.be/jlXeKfCD_9M
- NEW Datum Symbols and GD&T - Add datum and geometric dimensioning and tolerancing support in Drawings.
https://youtu.be/qSTuFJLTCUE
Linked[in]
Example 1: I edit an extrude feature. The Extrude in the FM gets the primary highlight and the constituent sketch (that is sometimes absorbed in other CAD systems) is highlighted as the secondary (light gray with a blue underline).
Example 2: I highlight a component in an assembly that is buried three sub-assemblies deep in the product. Starting from the top level sub-assembly that contains the selected part, each sub-assembly is highlighted with the secondary color and so on down to the selected part which receives the primary highlight.
Make sense?
The tool is awesome, real time saver!
Couple of things for future:
- Automatically fix orientation when using for mirrored faces
- When selecting face where is multiple same diameter holes with different depth, feature should pick just the ones with same depth as the original.
- Possibility to recognize hole groups, for example if hinge connects to 2x 5mm holes which are 32mm a part in x - it would be nice if feature could lookup such groups and insert subassemblies with multiple mates.
Exactly yesterday I was working Onshape-Rhino, I don't have any Rhino export/import options?
projektowanieproduktow.wordpress.com
Hopefully very soon we will have this.
