Programmatic extensions to Onshape
lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,001
We are looking for people to help us test a new and powerful way of extending Onshape.  If you are prepared to do a little programming, would like to get access to this functionality, and help us improve it before it is released, please fill out the survey here:
Programmatic extensions to Onshape survey
We look forward to seeing your responses!  ~Lou
    emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 860 ✭✭✭✭✭
    Hi Lou
    It would be great if you could create a webinar to explain the basic concepts of Onshape API
    Un saludo,
    edited December 2015
    +1 for API webinar / API for dummies blog
    @emagdalenaC2C I think we maybe looking at something different here to normal API  ;). However I'd be keen for a webinar on the basic concepts of Onshape API too.
    @3dcad I'd be heading to the dummies blog.
    Jeremy_21Jeremy_21 Member Posts: 7
    Hi Lou, I would love to be a part of extending some of Onshapes uses. Extending the use of meta-data, for BOM to MRP/ERP. Or project/document management and reporting. It's all very exciting! Thanks for the outreach.
    Sure. I am digging in the documentation now
    Un saludo,
    burhopburhop Member Posts: 22 ✭✭
    Just applied.
    BTW, I've got a good bit of code written already using the Onshape API including some Python wrappers and integration with Django. I don't know what I'm going to do with it but I did learn a lot..
    I'm glad to share if you get something setup for a dev community.
    Mark
    mcconnell113mcconnell113 Member Posts: 74 ✭✭
    +1 to onshape api webinar. coded a little in c# and a little in ruby. Assuming javascript would be the best choice here but again we know nothing about the api.
    John McConnell - Let's change things.
    Saplingstore.com
This discussion has been closed.
