Programmatic extensions to Onshape
We are looking for people to help us test a new and powerful way of extending Onshape. If you are prepared to do a little programming, would like to get access to this functionality, and help us improve it before it is released, please fill out the survey here:
Programmatic extensions to Onshape survey
We look forward to seeing your responses! ~Lou
This discussion has been closed.
It would be great if you could create a webinar to explain the basic concepts of Onshape API
@3dcad I'd be heading to the dummies blog.
BTW, I've got a good bit of code written already using the Onshape API including some Python wrappers and integration with Django. I don't know what I'm going to do with it but I did learn a lot..
I'm glad to share if you get something setup for a dev community.
Mark
Saplingstore.com
