Making unique copies of a part
Jonathan
Member Posts: 17 ✭✭
Hi all,
I have the following situation:
I want to produce several parts that generally have the same shape, but they differ in some of their parameters.
my original strategy was to make one of them, copy it, modify the original and repeat until all parts are made. This does not work because the copies change their characteristics together with the original...
My question:
Is there a way to make a part-copy unique and independent from the source, so I can change the original and have the different copied version too?
OR,
maybe anyone can recommend an altogether better approach to this problem?
Thanks,
Jonathan.
My question:
OR,
Thanks,
Jonathan.
Are you working in an assembly? Or in a part studio?
If in an assembly I copy the part studio (copy the tab not copy in the assembly) and then use the unique part from the second studio. Will that work for your issue?
If in a part studio when you copy a body the new resulting body is unique and should not change the parent or child. (FYI this can be used as a augmented version of the above and not have to create two part studios)
LearnOnshape facebook group
I work in the part studio, although the tab copy option will work for me.
About the 'copy body' in part studio:
1. I guess now it changed to Transform --> copy in place ?
2. When I do it (copy in place), and then make changes to the sketch that created the original part, the copied part changes too. Maybe I should only make direct changes, not via the sketch, in order to make unique changes in the copies? or is there a way to make a copy of a part including its sketches?
Jonathan.
Thanks,
Jonathan.
Interesting idea, I didn't explore branches before. However, I would ultimately need all the parts in the same assembly so it is not relevant for this task.
Jonathan.
yes, Ben mentioned too this option earlier in the thread. I guess that's the way to go about it..
Thanks,
Jonathan.
So I guess I should put in a feature request for the ability to right click a copied body in a part studio and be able to make it into a dumb solid or a new instance of the body with all features and sketches attached to the body. And the ability to define this when copying a body. (is this already in the list of things to do or work on @LouGallo ?)
If you think this is a good idea I would suggest you all make this request so that it would bubble up from the bottom of the enhancement requests.
One thing I am LOVING about this testing is our ability to help shape the product. I know we actually have a say in the development of this software unlike most other packages.
In SW (non-virtual), because it was file based:
-2 different files-independent,
-1 file-dependent right?
But who wants to go back to file based stuff. You need both dependent & independent instancing in CAD, but when and how it happens..... I'm not sure it's right in OS yet.
OS allows you to switch bodies between dependent & independent instancing but its tied to branching & merge which isn't as obvious to understand. That's why Jake is offering up the branch concept as a solution to this problem. But because you can't bring it into an assembly, well this is useless, strike 1. Not to mention the fact that part studio's don't offer instancing which is what I want, strike 2.
Ben is right about this being an issue on learning how OS handles this. I figured it all out a couple of months ago, but today I can't tell you how it works, I forgot. You should listen to Ben not me.
Ummmm ok, well I am going to go and try the branching method to see if that works out. I am trying two wrap my brain around if that will work or not.
And listening to me can be a slippery slope Careful when you do...
Now we have to deal with the tab management issue
Im going for a break cause my mind hurts from thinking about his...
-duplicating a part studio creates an independent instance of the part studio
-copying a part studio inside an assembly creates a dependent instance of the part studio
I don't know if things have changed, but this was the behavior a couple of months ago.
