How to extrude a solid with holes
I have a gear drawn imported as a DXF and added to a drawing (See the attached image). I can extrude the drawing as a "Surface" but when I extrude as a "Solid" just the outer perimeter is extruded. That is, there are no holes in the gear. How do I get this as a solid? I looked at adding faces to the front and back but don't see how to do that either. Basically I just want to "fill" the space constrained by the front and back planes.
W
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
This is common problem with imported geometry, the shape must be cut in the place where it draws a line on surface. Try to hover the shape, does it select whole shape or just part of it?
It is pain to connect heads one by one considering that Onshape doesn't allow adding coincident constraint by selecting area with multiple endpoints.
I would suggest using 'use/project' feature to replicate the shape in new sketch, make sure it's continuous and circular pattern the rest.
Good luck!//rami5 -
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
@jeff_mcafferlooks like you've got it sorted, an easy mistake to make when starting out and ending up with surfaces rather than a solid. As @3dcad said it's worse when working with imported dxfs as they have no constraints.
Tip: Once a line is black its full constrained. This is the way I like to leave my sketches, although you will find its hard working on imported geo.
If you have lots of gears to do it might be worth building a variable driven blank, once you have got the first one woking then do a copy of the tab and adjust variables to drive the new parts. We are all here to help to get it going for you, we may even be able to collaborate on a shared doc for you.
This public doc may be a good start. https://cad.onshape.com/documents/c9a5ab9cc17f4a71b44f9828/w/fe9439076f8347d981a9c624/e/f8117c468d9249649a3ec5755
Good luck!
Thanks!
