Pin/Slot Mate Examples
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
In the help documentation we show how to add a pin/slot mate in Onshape, however the example shows how it works when there is a blind slot.
https://cad.onshape.com/help/#pinslotmate.htm
If your pin/slot interface has a through slot which does not have a "floor" to it, here is how you can get this to solve. Simply follow all the same steps but hover over the top face the slot is cut through and while holding SHIFT, pick one of the mate connctors on the radius of the slot.
I couldn't get them to work properly until I adopted this. Lou might be able to confirm this.
