Inference of intersection point between plane and solid
Jonathan
Member Posts: 17 ✭✭
I built a plane that cuts a solid at a certain point. I would like to use one of the intersection points of the plane and the solid in a new sketch. OS doesn't seem to "infer" that intersection point.. Is there any method of making the plane useful in this sense?
thanks,
Jonathan.
thanks,
Jonathan.
1
Optionslougallo Member, Moderator, Onshape Employees, Developers Posts: 2,002Andrew_Troup said: Jonathan
This has since been implemented: you can now create a coincident relation between a sketch point and a plane, or a planar face.
(Something Sldwks still cannot do)
Hopefully it will eventually be enhanced to allow a relation with a non-planar face.
@Jonathan This as added in our last push.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.6
There's no inferencing for edge entities passing through a sketch. This has been registered as a bug.
After you are done inferencing to the edges of your sliced part. You can mirror it back to create a whole and boolean it back together. If the part isn't a mirror, then you'll have to copy it cut'm in half and frankenstein stitch them back together.
This isn't optimal, it's pre-production.
As you said, the method you suggest is quite complicated - currently i'd try to "find" my point with constrained construction lines, and hopefully soon this feature will be available..
Jonathan.
yes, referencing a plane in a sketch is exactly what I've asked for... is it already available?
Jonathan.
Thanks!
