Copy part in tab
ka_wang_lee
Member Posts: 1 ✭
Optionslougallo Member, Moderator, Onshape Employees, Developers Posts: 2,001@ka_wang_lee Currently you can copy/paste Part Studios but not one single part. I can add you to that request.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
Insert one of each Part studio to assembly tab
Next, translate the assembly into a Parasolid tab, and then translate that tab back into the Onshape format making sure that you select the ‘Flatten’ option. Now you have all the parts in a single part studio.
It also bears emphasising: this is a temporary workaround to plug a short term gap in capability, but the concept has broader applicability, so it may be worth adding to your arsenal.
So the only way to import a cad block is into an assembly, or at least you can't import into an existing part studio tab? This seems to negate the training video that says drawing all your parts in one part studio instead of multiple studios is the preferred method.
Inside document you can also derive part from another part studio.
Let's be patient with cross-document references - we know they are under development and we all probably agree with Onshape that quality is no. 1 priority and release schedule is just in top 10.
Hi,
How can one Translate an Assembly into a Parasolid Tab, and then back into an Onshape Format? Do you mean Export and then Import back?
Thank you.
Joseph
Yes, export to parasolid then import back.
