Multiple parts on one sheet
william_de_la_vega
Member Posts: 2 ✭
I have made a simple assembly of a box. I would like to make a single drawing with all the parts on it to use as a cut list. Each part would only have a single view since all the parts are planar with the same thickness.
I already was able to make a drawing of the assembly, but that is not what I want.
NeilCooke
Moderator, Onshape Employees Posts: 5,926
Hi William - press the Drawing View button, then the Select Part or Assembly button
Senior Director, Technical Services, EMEA6
The cursor changes to a selection cursor.
The view is aligned and the command mode is exited.
What I want to achieve is to horizontal align e.g. the top-views of parts - see my example on
https://cad.onshape.com/documents/5816f17c0bcfc7111e6a2971/w/bd20e8377b756bc97ce7d67d/e/57c972578c1daca91e439deb
You can only align parent/child views.
Note: you will also lose the ability to align a child with its parent if the parent has a "broken view"
(Not kidding about needing to be fixed though)
https://forum.onshape.com/discussion/6135/drawing-align-views-using-element-edge-point
So please vote this up!
