Feature mirroring
Raym_Koch
Member Posts: 27 ✭✭
Placed a feature in a part, and tried to mirror it with respect to a plane.
Result: "Failed to create face pattern, check input", regardless of what sequence I try to get it done.
I have done:1) Mirror command, 2) pick elements, 3) pick mirror plane
Can't figure out what step I am missing out not doing correctly.
Thanks.
Thanks.
1
Here's my public document:
https://cad.onshape.com/documents/c20d43a797e02b27f87429a0/w/12982f5f1e077dd9ed355c4a
One tab with the failed face mirror (as you have), and one tab with the workaround method I described.
Thanks you all for looking into this. I will have to use a different method to do this project.
I am using the OnShape App posted in the App Store in my iPad Mini, iPad Pro and iPhone 6. I am just fascinated by the fact that I can create a 3D part and assembly in those devices. Otherwise, if I HAVE TO USE A COMPUTER, then I have access to IronCAD, Inventor, Pro-E and SolidWorks, and the data is in my device.
However, by playing around here I am beginning to see the benefits of the Cloud "Stuph". Very interesting.
Erich Koch (dms-cad.com)
Face mirror in lieu of a "Mirror Feature" just doesn't seem to cut it. literally.
With all respect, please don't ask us to formally report bugs. It should be more than enough to report them in forum especially if we see that there is someone with 'Onshape employees' -status following the discussion.
https://forum.onshape.com/discussion/1064/how-do-i-mirror-this-feature#latest
I got the impression that only mirroring sketches was possible and an IR was raised back then. If someone could confirm that the IR was not raised, I would be happy to raise an new IR.
I think you need some improvement on these tools, Onshape employee should be able to create a group ticket for all of us when sees a discussion like this. It is not convenient to expect that everybody who needs proper face mirror will 'complain' about it using feedback tool.
I'm not complaining, for me the feedback tool is one of the most used tools
Sorry about this kind of question, but I just found this program about a week ago.
(A friend that uses IronCAD was fascinated that I created two parts and constrained them, all in the iPhone 6)
You can create variable before sketch: groove_length=50 and use it in sketch #groove_length (or #groove_length-50*12/6 + #another_var)
Where can I go to read more about that particular subject? And if that information is done before the sketch, where does one store that information for later retrieval?
Thanks a lot.
https://cad.onshape.com/help/#variable.htm?Highlight=variable
Onshape has very good online help site, which is also accessible from each tool using small ? in feature dialogs.
Variables are stored in feature list (in user POV).
That being said, the folks from OS monitoring the forum should be able to set priority based on number of forum entries. I mean if 200 people were on this discussion complaining, that should be raised high, even if one person logs it. We have such a feature in our bug tracking system, where some bugs are rated critical due to their nature (user pressed button and a cute puppy died) while others are because they see tons of users complaining, just not to support. We recently had an internal issue like this, where our outlook web client would quit (desktop worked fine) randomly after 10-20 seconds of logging in. I came onto the hospital ward and everyone was complaining, but nobody called the help desk (who out of 18000 employees had gotten 2 calls - so they thought it was those users); luckily as someone who also has an attachment to IT I managed to get the report to state "every user on this ward and 2 others where I work has experienced this". The support person raised this from low-priority individual report to critical, and it turned out to be of course a huge network problem that nobody knew about.
