I still wouldn't be able to push Onshape in our organization without drw capability.
At the same time, it bothers me endlessly that I spend WAY more time on drafting properly than on actually modeling in 3D. It just doesn't feel right.
I agree that in the end PMI & MBD will (have to) win out, but we're a long way off from that...
Dries
MBD is now and has been an ASME (Y 14.41) standard for a while. This has been worked on for quote a while. DOD, aerospace, and auto are all looking at moving more aggressively in this direction because it ultimately costs less and leads to fewer errors. I've read several places that some contracts will now require that the technical data package be formatted in this manner.
Tolerance analysis software, CAM software, and inspection software (both on machine and off machine) that can utilize this information is where industry will trend. It's so much more efficient in the long haul.
Do you happen to have a Pro/E v1 part file? Guess what, it's in there, it's been there for a long time.
It's always been put in the part and show in the drawing.
SW users were always afraid of using "insert model items" and this concept was kinda lost, this is nothing new.
SW won't define this, it's too late for them.
We need a translation standard that moves this meta data along, step needs to be updated. I still don't know the tap thread when I export a file and have to go off of the tap drill size, crazy.
Hope onshape will re-define this, it's a long stretch, a lot of guys still want to use dxf.
UX/PD/Community Support
I don't think having a display in the weld shop is an option. Someone will blow air arc spatter or direct a hand grinder on it and destroy it. We have enough problems with key boards and mice in the machine shop. Touch screens are a joke in a job shop environment so don't even suggest them, been there and tried that.
With SolidWorks and their problems with old assemblies blowing up I don't see using their models and MBD as the only documentation of a product. About every 5 years you may spend several hours fixing what was good in the version prior on a large part count assembly.
http://www10.mcadcafe.com/blogs/re-use-your-cad/2015/02/15/solidworks-world-2015-focus-on-mbd/ Look near the bottom where it talks about projecting PMI right onto the physical part. Closes the loop. Ties the virtual definition to the physical.
Sounds nice, anything to rid this world from 2d drawings. I question pdf as a standard having bricked 2 windows computers because of embedded viruses distributed with pdf. She didn't mention attaching virus's to the pdf that could kill your entire project/computer.
I think whoever developed this needs to go back to the drawing board and re-think this solution or you better keep your virus shield up to date.
@Bill Yes, I don't think PDF or eDrawings is the right medium either. I was more pointing to the fact that Blake Reves is working to make eDrawings a platform that will display PMI directly over a physical part. Augmented reality I think will arrive quicker than most think. I don't think this is pie in the sky stuff. I'm a bit of a dreamer, I suppose, but this looks to be within the realm of possible and pretty soon. This was just tweeted out...
http://m.bizjournals.com/washington/blog/techflash/2015/02/on-the-next-step-for-virtual-reality-it-s-all-in.html?r=full
Was thinking about adapting a Kinect that could watch my fingers allowing me to push holes through plates and squeeze things to size. I find it difficult to return to my limited mouse after using a multi-gesture ipad.
You are absolutely right about a change coming soon. Someone's going to share a box of crayons with those of us who only use pencils.
https://www.youtube.com/watch?v=QVhgUs3_RGU
Do you think if I design something heavy I'll grow muscles?
http://www.iotjournal.com/articles/view?12718
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
760 809 9046
fish tacos by the beach!
It rained here last weekend, hope that makes you feel better.
LearnOnshape facebook group
Fish tacos were fabulous, wish you were here!
