Need Help making 45 degree cut
in Drawings
Can some one show me how to make a 45degree cut in an extruded 2x2 square tube. I can make the tube but im having a hard time putting a 45degree angle at one end. or point me towards a tutorial thanks.
Build geometry:
1. add a chamfer, select an edge RMB (right mouse button), pick on chamfer
2. do what neil says, but add 45˚ draft to the extrude/remove to get the 45˚ cut.
Drawings:
Why is this under drawings? If you want to add the callout to a drawing, I have no idea.
