Tiny addition
jordan_2jordan_2 Member Posts: 2 ✭✭
Could we get the double-click to drop the line tool in Onshape? It really speeds up my workflow in SolidWorks and I miss it. Cheers! :)
  • kevin_quigleykevin_quigley Member Posts: 306 ✭✭✭
    Great idea - same could apply to all tools?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    edited February 2015
    @Jordan Double click seems to work for me currently.  You can also click+drag to do a line that ends when you release.
  • jordan_2jordan_2 Member Posts: 2 ✭✭
    @LouGallo : Double click right now ends the feature after I've drawn the line, which is a bit annoying. Let's say I draw a line to a point, then I want to drop the tool without drawing another line; using the current system, I will have to draw the line I want, end the tool by double clicking, which draws the line I don't want, then go back and remove the extra line. It would be better if double clicking dropped the tool and did not draw the current object.
    @Jordan  - Just double click at the end of the last line you want. It will draw the line and then "lift the pen". Technically, it's one step faster than SW.
    @LouGallo - I always forget about the drag!
