Delete imported stp Files
shai_perednik
Member Posts: 56 ✭✭
OptionsHakro Member Posts: 67 ✭✭✭You can delete the STP tab without any negative effects to your part.
5
Currently, with the update imported files improvement, it will delete the created part. There is currently no workaround.
For what it's worth, and I might be in the minority, I'd prefer it wasn't linked, or at least had a choice to link or not.
Hello! I have been trying to re-import & regenerate the deleted imported part I accidentally deleted but no the newer imported file opens a new part studio doesn't link with the one I need to. What should I do? please suggestion...
