Functionality needed for metal casting (and plastic part design)
pete_yodis
                    OS Professional, Mentor Posts: 666 ✭✭✭
                    I've submitted tickets for the following functionality and I'm sure others have for some or most of it as well.  I've been re-modelling a design in Onshape for a decently complicated metal casted component that I recently just finished in SolidWorks.  I wanted to see where all the pain points are.  I can't go too far at the moment because of lacking capability (split line and Parting line Draft).  Here is what I need in order to be happy with metal casting design (and plastic molded part design as well):  I have ranked them in order of most urgent in my eyes...
- Split Line or Split Face tool: This is needed to create parting lines to control the drafted faces. In my workflow I generally put this just above the draft features, and before the fillets - but not always. It would be nice to split with a sketch, surfaces, planes, and the intersecting edges of bodies. Sketches would be priority and the rest as time allows.
- Draft - Parting Line Method (with stepped draft for those nasty bits...): The parting line draft tool almost goes hand in hand with the split line/face tool. If I can't have a parting line draft tool, then split line is almost useless at this point.
- Base part: - I really like using the base part method. I detail up a casting in a separate, clean, isolated file (I know, I know, files really go away in Onshape but its a habit). I then insert that part into a blank file and complete modelling the machining features. This keeps the data management nice and clean.
- Draft Analysis: Parts can get really complicated and its easy to forget adding draft to a face. Casting vendors use this tool like crazy, too...
- Thickness Analysis: Ditto above.
- Geometry Compare: I really like comparing a casting design to a machined casting design using a geometry compare. I can quickly check to make sure all my machining allowances are proper - not too much, not too little. I also use this for getting an amount of material removed, which is really useful for costing estimations based on material removal rates ($/lb of removal).
2
All other feature are need, I am sure they will come in time. I don't do very much of this work but have defiantly looked for the split line and draft tools.
The other features will no doubt come in time. Thought I would share where I am at.
- Split part: https://cad.onshape.com/help/#splitpart.htm
 - Draft https://cad.onshape.com/help/#draft.htm
 - Base parts: granted this is not parametric but try duplicate tab: https://cad.onshape.com/help/#introduction.htm or play with the branching and merging so see if there is a workflow in that. https://cad.onshape.com/help/#versionmanager.htm
Food for thought...LearnOnshape facebook group
Pete, I would do this by rolling back to just above the copy on the tree in the part studio, that way any changes blow through to the machined casting. I don't see why this would not work as well as method you use in Solidworks. I will try and do an example.
to be a useful part design tool for production use in injection moulding or casting you need split line capability. Split line tool is also essential for many other tasks relating to surfacing.
I find myself missing it every day I use Onshape.
Dries
-Extrude Draft: All add, new, remove, surface need to have this option.
As usual, specific workflows or examples are useful in determining what and how it should be implemented.
OnShape is not a serious modelling tool unless it has this functionality. I for one expected Onshape to be pushing the boundaries of what creating geometry means. Currently this is not happening. You are pushing boundaries on the delivery mechanism of the system to the user. But that is pointless if the tools they have available are unable to create what they want. You need both.
So back to my point. How do we take these rudimentary tools we have and create a workflow to do what you need. Even if it is long and arduous. The reason is it will give the developers a workflow to base the next iteration of changes on this sort of workflow. I fully get that it is a PITA but in the end the benefits of letting these guys into our minds is a awesome tool in the end we all love.
We have taken the first step by identifying tools that sort of do what we need and suggested the improvements to get them to the next step. For example:
"Onshape right now is basic from face only. Not from parting line. Makes doing a lot of detail part design work impossible. Yes you can draft if you have a flat surface or plane but not from a curved or stepped split line. to be a useful part design tool"
I think the next step here is to let them see about doing curvy split lines and draft combinations. Given how fast and furious changes have been coming I bet it will be implemented in short order.
@BruceBartlett I'll take a look at that method. Thanks.
Another method I've seen work in Solidworks is to drop the the casting into an assembly and add the machining processes with cut extrudes and hole feature's. I'd like to think Onshape will have this functionality in their assemblies also in the future and could be a work around if added however I think their need's to be the ability to add parts in a part studio, I have often had the need to add an imported part into a part studio.
The assembly cut features in SolidWorks were limited compared to cut feature capability in part files. I never liked to use assembly models to cut material, unless it was an assembly like feature - drilling and pinning a gear to a shaft for example. Other than that - stick to base part insertion of the casting and then machining features. Very clean, capable, and robust.
Regarding the Part Studio with transform/copy part to accommodate base parts - Something needs to be done to simplify the view of which features apply to which bodies. Right now, it would be unnecessarily complicated to invite a casting vendor into a casting and machining design and have him be a part of it. It needs to be more simple. I would have to give him access to the whole kit and caboodle. I would only want him changing the casting, and not the whole casting and machining. That is another advantage of something like base part. It's too complicated at the moment and it doesn't need to be. People won't naturally move to overly complicated tools.
Linked[in]
Granted, the draft on text is not really needed to be in the model (typically doesn't change the mass by much in plastic parts), and toolers know how to machine it properly, but I'm a stickler for details.
Linked[in]
Is this for the design of the parts for this process, or the design of the tooling for these processes, or both?
Spure, gate and runner library.
Analysis
Library of standard mold components: leader pins, bushings, mold bases etc.
Sprue, gate and runner could be derived parts but maybe a different route would be better.
If I need to create a runner. It would be nice to select a sketch, then in a dialogue window....define the runner parameters- shape (half round, full round, profile etc.).
Same for gates- Select a sketch point and then define parameters.
Same for sprue.....or just import the sprue bushing which would define the profile.
Mold flow analysis is a must to compete with our current package.
As far as suppliers- dme is a great start.
Thanks for the supplier reference.
What do you use for mold flow analysis currently?
