View Cube in Safari
GWS50
Member Posts: 491 PRO
The View Cube has disappeared. I'm on an iMac running El Capitan and using Safari.
It seems to re-appear when I switch to Firefox.
Anyone have a clue why this should be?
Many thanks
Many thanks
I see the view cube disappear in Chrome when I make the window full-screen on my external monitor (display scaled to 3360 x 1890)
Interestingly the view cube stays in the right place and fully visible when the window is full width but only 2/3 or so of the full height, then as you continue to drag down the bottom edge of the window the view cube progressively slides right and out of view...
Was this a driver problem or something else?
