FIXED - Documents Shared as "Can View" can be copied by the shared user.
I just tested with my second account and I can copy workspaces when they are shared as can view. I can even copy them straight out into the public space in just a few clicks. Even worse, copy to public is what would most likely be the case if someone on a free account wanted to copy a large private doc shared with them.
I don't think this is right. If I share with somebody as "can view" I expect them to be only able to view the document or view and comment "Not Copy Workspace". To me this is limiting Onshape's collaboration ability by restricting the share to only full trusted associates.
Do others feel the same, or is this just me?
9
It looks like you actually brought this up last September as well:
https://forum.onshape.com/discussion/1630/shared-documents-security
Any progress on this OnShape?
Shame because onshape is a great way to fully view a 3D model but NOT if by doing so the person you share with can take all your design work for free and then move forward using that design. I think a jpg image will be safer for now!
We need full control over shared stuff:
- can edit
- can view
- can take measure
- can copy&share forward (if possible these should be two separate things)
+ possibility share just part of document
I would like also to see all the time the participants 'letters' on top bar so I remember that I'm working on shared document even if collaborators are offline.
Offline collaborators letters could be greyed out.
And user should be noted when someone follows you.
And we really need a simple text chat (+voice if easy to implement), commenting is not suitable for this use.
I know there are loads of free chats but if I take 15 min to go through something in 3d model with customer/supplier I'm not going to use that time to ask them to install same chat that I have. I don't like to have phone conversation active all the time.
what else?
UX/PD/Community Support
Should be simple check boxes when you go to share:
View (implied)
Measure [X]
Copy [X]
Edit [X]
Each successive permission implies all the ones above it, so maybe a radio button
or a slider:
Private - View Only - Measure - Copy - Edit
I would go for full list of choices and let user create custom share profiles for easy and quick sharing.
I think the most important thing here is Private Doc's, normally in the Paid Subscription need the flexibility to be shared around without the risk of people copying the whole workspace. I'd like to be able to share people into view a doc as if they had come around to my office but once they leave there is nothing they can take with them with them. To me, I am now very caution with share of material which is of confidential nature, however the strength of Onshape is in this sharing ability. Looking forward to some progress in this area.
_Dave_
When paying for a professional account I think it's reasonable to expect to be able to fully lock down your workspaces when shared so they can't be copied. You should only be able to copy workspace when the Can edit & share is checked. Export should be allowed at the lower levels but not copy workspace.
I'm hoping to see things like allow adding parts but not taking copies etc.. This will be a major question when Onshape has more users and actual work-collaboration is done more. I wan't to be able to share designs in website without fear that anyone could just grab a copy nor be able to take more measures than I have allowed. So control should be really deep all the way to feature/dimension level.
That is why checkbox option list would be very long and not good solution for every share process - I would like to have few standard share profiles: Allow all, Edit, Read-only etc.. + custom share profiles where one could define exactly what is possible and what is not.
So that I could create a profile where:
copy = false
export = false
read = true
shareOnlyMarkedTabs=True
shareOnlyMarkedVersions=True
featurelist=false
showSelectedDimension=True
measure=false
.. you got the point
Then I would name this profile as 'Client_share' and it would appear to my dropdown list for quick select when sharing document.
In my opinion urgent requests should be made through ticket system so that they get filed immediately but here in discussion forum we should also paint the future without any concern how/when Onshape can cope with our ideas.
What are your ultimate thoughts for share control?
_Dave_
View only should be that, any attempt at 'copy' or 'export' should be prohibited. The 'share' should also expire after 2 days or a setting box value.
Another request I have is is to only share a specific version or branch. I.e. save a version called "V1 for quotation" and share this with vendors but not allow them to see the other work that is taking place on that doc.
This will make share system become too complex. I think..
My main targets for share would be
- collaborator = full access
- sales = no-sign-in full read access
- vendor / customer = no-sign-in limited access
- end user = no-sign-in very limited access
It is not convenient to make copies just to be able to share a tab with vendor / customer. Vendors only need to see the part they should deliver and most of time customer should only see the final design in simplified environment.
To be able to use shared model as part of end-user documentation we should be able to create special named views and strictly control how it's showed to visitor.
Therefore, Onshape is still missing 1) commenting on versions (no other edits, just comments), 2) a View and Comment option, 3) private only for shared documens (therefore could not be moved into public space), and 4) part/tab specific sharing of a document. Without these 4 items, I would have used the old fashioned method of making a set of prints or pdf files to get a design review sign-off with a customer. I would not have shared directly from OS, which is a shame since a customer could do a much more thorough review by looking at assemblies and parts from any angle and any magnification level.
My issue was fixed. Onshape were straight onto it for me. If you share now as "view only" with private documents they can not be copied.
To add comments to a versions you will have to branch of that version, I didn't think that was a bad option as then you can still still the history in time of when comments are added.
Cheers,
Owen S
When in the machine tool industry, we would hold an internal design review (a good time to make a version that allows comments to be added from all interested parties) before making fixes and changes and then sending the design to our customer to review before completion of the design. This would be a good time to make another version that can be commented on and sharing ONLY THAT VERSION with the customer as "view and comment only." Not all customers are trustworthy, so the shared document would need to remain private to only that individual (or individuals) could access from their private documents. The need to make it public due to space concerns would have put our IP at risk. However, if they only had the free plan because they only needed to view our documents for review, they would not be able to access the document if it was larger than their allowable free space.
https://www.onshape.com/cad-pricing
