Color picker request
michael3424
Member Posts: 753 ✭✭✭✭
It would be nice to have a matrix with a few selections for colors that could be applied when setting Appearance on parts and even better if they could be customized. If nothing else, maybe the values of the "#" fields for the 8 standard part color definitions could be added to the help file. In the meantime I've resorted to a paper cheat sheet with those values.
Mike
Mike
2
I'm a tough guy and usually won't discuss pretty colors, but after staring at a project all day it does matter. I tend to like to make the parts look real so I use a lot gray shades. I really liked spaceclaim's pastel palette.
I tend to copy the color for a body into my clipboard, then selecting everything to change and pasting in my color from clipboard.
My big request though are to be able to change color's from assemblies without having to switch to the part studio.
Override a complete assy with a color to resemble the finished painted color.
And to be able to able to apply color to individual face's.
I have requested assembly color too, it is common in real world that same part is painted in different color for different assemblies. And it is also common that one face of part is painted in different color than other.
It would be also nice if white would look more like white as now it's mostly grey.
What do others think, should assembly be able to override material set in part studio?
I am currently working on an imported model plus extra modeled bits to get some quick renders but has been so time consuming getting the colour's right. I have ended up with a 1000 part's across 4 part studio's and it's almost impossible to find parts to change color's within the imported studio's so have been switching from assembly to part studio 1 by 1 to find parts and then set color. Not fun at all.
I can see an assembly override of color would be handy but at the moment I'd just like to be able to change part color or a group select of parts from the assembly without the switching to part studio. Don't care if it changes color at the studio level, maybe it is better if the studio stay's it original colors.
