Improvements to Onshape - September 14th 2016
NeilCooke
Moderator, Onshape Employees Posts: 5,310
Onshape 2017 is here! What?!? Sorry, my mistake, it's just the usual round of awesome new enhancements to your favorite full-cloud CAD. It's a lot of hard work creating these What's New videos, but I'd much rather do this every three weeks than once a year - enjoy yet another HUGE update!
We hope you enjoy using these new features - as always, all feedback is welcome. Waiting for a particular new feature? Please use the Feedback tool to request it - we're already hard at work on the next round of updates for you!
Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
MULTIPLE SECTION PLANES
The way you create section views in Part Studios and Assemblies has now completely changed - you no longer have to preselect a planar face before activating the Section View tool. You can also now select up to 3 planar faces to define your section, each with its own section view manipulator that you can drag by a defined distance, snap to model geometry, flip and rotate.COLOR PALETTE WITH CUSTOM COLORS
The Appearance Editor now has a default color palette to make it easier to assign colors to Parts. You can also store up to 55 custom colors (linked to your Onshape account) and use these colors in any Part Studio in any Document.
MESH REFERENCE GEOMETRY
Onshape now imports OBJ and STL files as meshes for use as reference geometry in a Part Studio. You can transform, pattern and mirror a mesh, derive it into other Part Studios, and use any vertex from the mesh as a reference for a plane, a sketch entity, or a feature.INSERT SKETCHES AND SURFACES INTO ASSEMBLIES
Sketches and surfaces can now be inserted into an assembly and used as reference geometry. You can use sketches as layouts in your assembly and insert imported parts that are built using surfaces only.TRANSFORM SKETCH BY VALUE OR BY SNAPPING
The Sketch Transform tool now lets you translate and rotate by exact distances or angles and snap to existing sketch geometry.RIB FEATURE
Onshape now has a built-in Rib feature! Simply create a sketch of the network of ribs and specify the thickness and direction.Z-AXIS VERTICAL ROTATION
If you hold down the ALT key while rotating your model, the Z-axis will remain vertical with respect to the screen.TAP DEPTH AND CLEARANCE
The Hole feature now gives you separate control over tap depth and tap clearance (number of full threads clearance at the bottom of the hole). Adjusting the tap depth will adjust the hole depth accordingly (and vice versa) and adjusting the tap clearance will adjust the hole depth.PLANE MANIPULATORS
Offset Planes and Line Angle Planes now have an on-screen manipulator to make it easier to approximate the position of the plane before entering a precise value.SEARCH FILTERS AND RELEVANT DOCUMENTS IN INSERT DIALOG
When inserting parts into an Assembly or creating a Derived feature in a Part Studio, a search field is now available when browsing Documents and using filters, helping you to find Documents faster. Also, when browsing for a Document containing a DXF file, image, or FeatureScript feature, the Insert dialog will show only the Documents that contain the object type you are looking for. The relevant Documents are displayed in bold and all other Documents are dimmed.SCROLLING VERSION GRAPH
When a Document has a lot of branches, Onshape will now add scrollbars to the top and bottom of the Version Graph. If you are using a trackpad or a mouse with horizontal scroll capabilities, you can also scroll the graph when the scrollbars are not visible on screen.TAB FOLDER NAMES
Now when you select one or more tabs in the tab manager, then right-click and choose "Add selection to folder", Onshape will prompt you immediately to enter a name for the new folder. If you want to accept the default name, press Enter or Esc.IMPORTED PART VALIDATION
When 3D data is imported into Onshape, each body is checked to ensure it is a valid solid. In this latest update Onshape now lists the names of all the parts that failed validation to make it easier for you to locate the troublesome parts.DRAWINGS
- Automatic graphics refinement - the Refine Graphics button in Drawings is no more. Onshape will now automatically refine ALL graphics based on zoom level.
- Performance improvements for notes - performance has been significantly improved when editing long notes or notes that use truetype fonts.
FEATURESCRIPT
- FeatureScript notices - now appear at the bottom of the graphics area in a separate resizable panel. This gives you the full width of the screen to read messages and ensures your model is visible at all times.
- New queries:
qLargest - finds the largest entity (by length, area, or volume) within a subquery.
qSmallest - finds the smallest entity (by length, area, or volume) within a subquery.
5
Special thank you for sketch transform and possibility to add sketches into assembly!
We will surely keep the feedback coming!
Bring on sheet metal and configurations/variants
Well done!
What are the criteria for when updates are being rolled out to existing documents? I've noticed that some of my documents has been upgraded, while others have not. I guess you have a queue of sorts, but what decides the order of that queue? Last modification date of a document? Document size? Free vs Pro user? Time zone of user (upgrading during the night might make sense)?
I guess there is no way for the user to somehow force a specific document to upgrade, other than wait for it to happen? It would have been nice if a document had been moved up the queue if the user opens it and starts working on it. Sometimes one really want to try out the new features on existing documents. I'm not sure this would really add much load to your servers, because this is more the exception than the rule, I'd guess.
Meshes took me by surprise...I'll have to check this out! Multiple section views is cool and colors are always fun. Thanks again!
Hmm...the color example seemed to end with a sheet metal part (or an excellent imitation of one). Definitely excited to see that in the works - can't wait for that update.
I love the rib feature. Much better than making a closed sketch and extruding, especially when you have curved surfaces to deal with.
I have not had any luck getting the z-axis rotation to work. Tried my Mac using Safari and Chrome with and without a mouse and a PC with a mouse running Firefox. Anybody else have this problem?
TAB FOLDER NAMES
Now when you select one or more tabs in the tab manager, then right-click and choose "Add selection to folder", Onshape will prompt you immediately to enter a name for the new folder. If you want to accept the default name, press Enter or Esc.I can't get this to work. I do not get a "Add selection to folder" choice when I right click on a Tab. (See attached image).
The only way I can move a tab into a folder is to drag it to the top level, then drag it into the appropriate folder.
I hope to comprehend this tree and its long vine-like branches eventually.
Other companies might be tempted to stock-pile new features and drip feed them. OS seem to push them out when they're done, tested and ready.
Not sure how many of the devs read the forums but please pass on my appreciation to those hard working souls.
Cheers,
Owen S,
This is a powerful capability of Onshape, so let me try to add some comments that might help:
1. Creating a version allows you to mark a design at a "point in time." This version is immutable (it will not change), you can continue on with the journey and make additional changes and then create another version - think of it as "snapshotting."
2. Branching allows you to explore different variations of a design. You can branch the design yourself (think of it as concept A, concept B...) or you can branch the design to allow a colleague to work independently of your work. Of course, you can merge changes back.
Try watching this video to see if it helps: https://www.onshape.com/videos/branching
Let me know what you think.
John
