3D Connexion Space Navigator Not Working
Mark_MatthewsMark_Matthews Member Posts: 25 ✭✭✭
I've read that this mouse is supported, but mine is not working with Onshape. How do i get it working with Chrome?
    Should note, I'm using Bootcamp to run Win8.1
    When you go to 3dconnexion settings from Onshape window, does it say Chrome or Onshape in settings title?
    Josy_LaJosy_La Member Posts: 82 ✭✭
    I also have the same problem. I see Chrome in the top left of that window.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,440
    edited October 2016
    Make sure you have the latest drivers  - if they are and it still doesn't work, please contact 3dconnexion they will be happy to help
    Downloaded the latest yesterday. It seems to work this morning I guess it required a reboot to work properly.
    mlml Member Posts: 53 PRO
    I have also sometimes troubles with the SpaceNavigator and the anti vir (kaspersky) reports an 'untrusted certificate' from 3dconnexion. I think my troubles are from there....
    Some days the 3D mouse does not want to connect to Onshape that is went I see Chrome in the window.
    lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,002
    Sometimes a hard reload of cache of the browser will fix it. SHIFT + Reload.
    JVBNZJVBNZ Member Posts: 1
    Thanks  lougallo that workd for me.
