3D Connexion Space Navigator Not Working
Mark_MatthewsMark_Matthews Member Posts: 25 ✭✭✭
I've read that this mouse is supported, but mine is not working with Onshape. How do i get it working with Chrome?
  • Mark_MatthewsMark_Matthews Member Posts: 25 ✭✭✭
    Should note, I'm using Bootcamp to run Win8.1
    When you go to 3dconnexion settings from Onshape window, does it say Chrome or Onshape in settings title?
  • Josy_LaJosy_La Member Posts: 82 ✭✭
    I also have the same problem. I see Chrome in the top left of that window.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,847
    edited October 2016
    Make sure you have the latest drivers  - if they are and it still doesn't work, please contact 3dconnexion they will be happy to help
    Downloaded the latest yesterday. It seems to work this morning I guess it required a reboot to work properly.
  • mlml Member Posts: 53 PRO
    I have also sometimes troubles with the SpaceNavigator and the anti vir (kaspersky) reports an 'untrusted certificate' from 3dconnexion. I think my troubles are from there....
    Some days the 3D mouse does not want to connect to Onshape that is went I see Chrome in the window.
    Sometimes a hard reload of cache of the browser will fix it. SHIFT + Reload.
  • JVBNZJVBNZ Member Posts: 1
    Thanks  lougallo that workd for me.
