3D Text and Cut threads
Hi
Got some feature requests to add text that can be placed on the models and extruded or cut. just simple fonts for labels and part numbers etc. and ability to create cut threads into cylinders or holes. similar to creating a helix but with the ability to enter thread dimensions which it then cuts or extrudes.
Hopefully at some stage there will a hole wizard tool like tool, could be a way off but hopefully not. When drawings come there will need to be a way to do cosmetic thread to show the edge. I have tried adding helix to bolts, at the time the idea was to check thread length in assemblies bit of work but can be done.
https://cad.onshape.com/documents/516b1784884d4facbc4c0d74/w/8e947edb43904354bb16b3f2/e/589eaf71321043e28046aac0
You mentioned 'simple fonts' but are there any specific fonts that you would want Onshape to support?
Also, how would you want to define the size of the text?
http://help.solidworks.com/2014/English/whatsnew/t_using_stick_fonts.htm
UX/PD/Community Support
threaded features are very helpful for 3D printing.
Usually I don't model threads in parts. I simply annotate on the model or drawing.
However, if those parts are to be prototyped through 3D printing, then modeled threads are obviously required. Creating threads through sweeps is kind of a pain.
Dries
this way, you have access to any typeface in the library, not just locally installed ones. As far as I am aware, nobody in MCAD taps into this yet.
for features like threads, lets be totally frank here. Users do not want to be modelling threads. They want to pick a face, say apply M6x1 thread. Done. For moulded threads there is no reason why this cannot be automated as well. Sketch the custom profile (or pick from a library of recommended plastic thread profile. Pick the face, apply pitch, lead in and out parameters, done. VX had this very tool 15 yrs ago. I still miss it.
the same thinking needs to apply to all common 'features'. As a designer, Im intersted in spending time designing and thinking, not about modelling repetitive features or trawling through libraries of parts to look at best practise design for joints, fastening, bosses etc.
so far, I have not seen any CAD system that delivers this type of thing with reliability, speed and range of options. There is an opportunity there and I can't help think some of this stuff would be easier to implement than advanced surfacing features, which lets be honest here, is not going to see light of day any time soon is it.
This is simple and fast for the user.
Arial and Arial rounded would be good. the more it can support the better. As mentioned above, ones that are CNC, lazer cut friendly. but for people that 3D print then all fonts are welcome.
I have never worked with the perfect sizing solution for modeling text. So i cant really give a good answer on that. But if you a initially able to enter the height, which would be the height of a capital letter. but then have constraints that you can alter after placement would be good.
We should split this thread so we can discuss text and thread/design features separately.
We currently plan to size the text using dimensions/constraints only.
Ideally I want chose a point then chose Left Justified, Right Justified or Centre. Less important but handy would be top, bottom,centre. I have always struggled with text positioning in other CAD, I find it a bit clumsy.
Linked[in]
If you were to include a centered bounding box around the text that could have sketch constraints applied to it, I believe that would also fill the requirement.
I absolutely agree with @BruceBartlett that placing text has always been a bit clumsy in existing systems.
-Ricky
BTW, if I had text in Onshape I would chosen it for this little job rather than Solidworks. It's a laser cut name plate.
As far as text selection the more options the better as each customer has there own likes and dislikes. As one previous post said he made his own so maybe the option to download your font into the design and use it???
As far as text modeling... very much needed. Often needed for machining on cylindrical surfaces. If images can be placed on the plane and sketched over then most anything can be done. I have clients in the woodworking industry that want me to machine brands for them so they can burn their logo into their projects... can supply pics if anyone wants to see the finished product....
