How to constrain motionless parts?
Josy_LaJosy_La Member Posts: 82 ✭✭
Our assemblies do not require movement therefore I always use the fastened mate when I have matching holes conditions. But some of my parts don't have holes but still need to be fix in a precise location. How can I mate them without the use of mate connector?
  • Josy_LaJosy_La Member Posts: 82 ✭✭
    Ok thanks I see what Planar mate can do for me. It is an acceptable solution easy to work with.
  • bill_danielsbill_daniels Member Posts: 278 ✭✭✭
    How do I precisely position a part IN CLEAR SPACE where there is nothing to place a receiving mate on?  I know the exact XYZ coordinates where I want the part to go relative to the origin.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    @bill_daniels use a fasten mate on the origin then use the offset option to specify your XYZ location
