Is there a way to make a model from Drawing?
in General
In Maya you can import a drawing onto an image plane and build your model based on that design. I can't see how to follow that same work flow in onshape. I"m sure it exists, but I haven't found it yet. Is it possible to do something like this example file of the airplane?
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
No it doesn't exist yet.
This is desperately needed so put in your request with ? top right.
What are you thoughts on format DWG/DXF, .AI(illustrator) or other ?3
vector formats (dwg, dxf, .ai)
but .ai should import as curves not a gazzillion line segments
As far as image format goes, I would like the vector formats as much as the next guy, but I really care about the bitmap formats so I could import a drawing that I did from hand.
Maker, DIYer, tinkerer, bourbon lover - Antics captured on StuffAndyMakes.com and OfficeChairiot.com
Youcan do that now
