How to color selected surface of part?
OK, here is the problem, I will create 3D model by using ONSHAPE. It is solid part. But how can I change the color of selected surface? I know how to change part color. I do not need to change part color. I need top change the color of selected surface. Thank you for any advice.
1
Both are requested features and you can add your vote in 'Improvement requests' category.
Onshape does permit the colouring of individual surfaces. If there are only a few surfaces needing colouring, you could create a hybrid model, part solid and part surface.
Onshape, Inc.
@NeilCooke
It's only coloring faces, what could go wrong
