Working with Exported DXF/DWG Files...
With the latest push, we export a selected sketch or the edges of a selected planar face. Please let us know how you are using exported DXF/DWG files. What is your workflow? Are the DXF/DWG files being read into your "receiving software" as you expect?
As always... examples are very helpful.
Scott Harris / Onshape, Inc.
LearnOnshape facebook group
@scott out of interest, what version do these files come out?
I'd also like to be able to name the file from the dialogue or ideally pull the name from the part name or meta properties.
Ideally I want save the file straight from Onshape and it's done. I don't want to have to rescale or rename or even move directories.
We're investigating the units issue.
When I load in Draftsight to check, it comes up in thick lines, I think this because the layer set to .4 thickness. I would prefer no thickness, not sure if this is a Onshape or Draftsight thing. Seems to be related to the continuous layer the lines are exported on. I don't thick this is a operational issue with my sub contractor profile cutters just me being fussy.
Now I should be able to export straight from Onshape to the Laser, no draftsight/autocad involved.
We have lineweights on by default for regular drawing creation (yes, we're working hard to get that done!).
I'd be interested in hearing more opinions on whether we should turn lineweight off by default when doing DXF/DWG export of faces/sketches.
Please add units to the export dialog, default can be document units. I design in mm but have to export in inches. It's so painful to change system units to inches, export and then change back. A real waste of time and a lot like SW which is not a good thing. Please don't do this to me.
Please add units to this dialog box:
My system units are mm but I want to export in inches. Or, just change the world and remove inches from the planet. You can choose which ever is easiest.
Also, I'm using the official dwg/dxf validator and I'm getting this error:
I got this error for both dwg & dxf.
Since I do 99% 2.5D milling I import DXFs into CAM. I do 2D CAD in Draftsight, but use 3D CAD (SW) since I can export a sketch as DXF.
Bruce
Dries
/Scott
Really liking the product so far. Interface-wise it's an improvement over SW. Any timeframe for the drawing environment? it's the only thing keeping me from switching over at the moment.
Cheers,
Wiley
Both my document settings and account settings are default to millimetre.
@ritchie_argue
In spite of what was claimed in the document you linked, in practice dxf files are generally specified as unit-less, so that has become the de facto or ruling assumption in most disciplines where they are used.
If they are created from an inch document, one unit will be an inch; if from a metric document, it will typically be a millimetre.
By convention, any dxf profiles provided for cutting or routing or engraving will have at least one dimension attached, so the recipient can unambiguously verify the final translation is correct, and (if necessary) scale the profiles up or down (generally by 25.4), or change the units in the receiving package in cases where that's possible.
You can find general setting by clicking your name (on top right) --> manage account --> settings
Document settings can be found inside document, hamburger menu (on top left) --> units
At the moment Onshape is lacking any drawing or dimensioning ability, so you would have to kludge it by adding a suitable dimension in a sketch. I would create a sketch for that specific purpose, and "Use" the desired profile, to convert it into (fully defined) geometry on that sketch.
I would then add a (driven) dimension to that sketch, hide the parts and other sketches, and use a suitable screen-grab utility (like "Snipping Tool" in Windows) to take a snapshot of the sketch with the dimension, purely for illustrative purposes, to send along with the dxf.
If you have any other CAD package in which can open a dxf and put a dimension on it and resave it, that would be a better result, because you are only supplying a single file to the contractor.
