Is there a way to create a 3D plane surface in Onshape?
I need to draw a series of fabric roofs that are anchored at corners at different heights across their respective surfaces. I notice 3D planar drawing is an ongoing demand of Onshape users - as it is in practice. Has this need been resolved or does anyone have any suggestions?
Thank you.
Thank you.
If that is the case - @NeilCooke wrote a custom feature to do this - i am sure he will post a link in a few minutes
I thought he wanted a bounded planar surface and i know you had solved this.
Lets see what he comes back with
Webinar:
I didn't have my notifications set so I've only just noticed the discussion had grown.
Sorry if you used the wrong terminology (3D and Planar)- the end result concept of a fabric roof in tension hopefully helps. Each corner is at a different height, and each edge is curved in three dimensions- making it at the very least time consuming and complex to construct in CAD.
I am currently looking into using surface modelling (thank you carl_von_ayres for the webinar link). I will try and see if it works.
Below is the link to the model which I assume is something similar to what you are after, the first is simple [you can set the heights individually], the second has a opening in the top and the third part starts to incorporate guide rails.
I am currently having problems matching the four sections up [so I can boolean them together], I assume is due to how I based my sketches but someone with more knowledge of surface modelling could probably help you with this easily.
Link:
https://cad.onshape.com/documents/2cae6b8bd07a88a2e2458fb0/w/997a68310515c46b08a51a8f/e/35e8da40a8b8977e1515184a
With 2 2D sketches can I create any geometry any where? I think so.
Compound sketch defined:
-sketch on front plane defining 1 rotation
-sketch on this rotated face, rotation 2:
-sketch on this rotated face, rotation 3:
Add 3 translations:
That's 3 rotations & 3 translations. That's any where & any orientation.
So, instead of using one sketch to define geometry, use 2 sketches.
Look this is no substitution for a 3D sketch, but it does work and is fairly controllable.
