is it possible to display planes for mating purposes - the part is an imported rexroth extrusion
 Mike_Tracy
                    Member Posts: 1 ✭
Mike_Tracy
                    Member Posts: 1 ✭
             bruce_williams
                            Member, Developers Posts: 842 EDU
                    The mate connectors are an improvement over using planes. If the desired connector is not available, you may create mate connectors in the part studio or assembly. A trick from @lougallo is to add mate connectors to the origin in assembly which then can be used in place of the standard planes. Here are couple of past discussions on the topic - bruce_williams
 https://forum.onshape.com/discussion/comment/22813#Comment_22813
 https://forum.onshape.com/discussion/4517/how-to-mate-a-spring-in-assembly
 www.accuratepattern.com5
