How to bend a flange 180 deg
I can bend it 170 deg but not 180, why not
lana Onshape Employees Posts: 729
Limits on flange angle are 1-179 degrees. 180 case would not fit the feature design. e.g. , length of flange is measured from the virtual intersection of external walls. That why we will be doing a separate implementation of Hem as well.7
LearnOnshape facebook group
I was going to request a Hem feature too. I had a requirement for a safety edge and was able to achieve this by juggling the angle and bend radius and moving the flange edge but not ideal as it isn't 180deg and takes a bit of messing around. A single feature Hem would be perfect.
You can also see in this picture a requirement to align the first flanges flat around the top edge, it would be really cool if you could achieve this with a mitre on faces approaching with compound angles.
Twitter: @BryanLAGdesign
Also, if you use a "straight" hem (which you have) then it is 180 degrees - there is an offset (for kernel tolerance reasons) of 20 microns - good luck measuring that on a real sheet metal part! Saying it is useless is not helpful - if you want to suggest improvements, please do so in the category on the right -->
