Feature requests: Variable name niceties
jeff_streetjeff_street Member Posts: 8
  1. Auto-complete (e.g. in entry field for sketch dimensions)
  2. Auto-Propogate name changes through existing instances (e.g. if it becomes necessary to change a variable name, it's currently necessary to manually replace every instance of the the old name with the new name).
    Hi Jeff,
    Both of these would be very useful, can you make an Improvement Request from the menu on the right side of this page? -->
    p.s. #2 is often called 'Refactoring a variable name' when programming.  Definitely a good feature request.
  • jeff_streetjeff_street Member Posts: 8
    edited March 2017
    Found autocomplete in the improvement requests section too. Added comments there. Feel free to delete this post.
    In my ideal parametric cad (which exist only in my imagination) variables is just a part of high level programming language (like Python or Wolfram Language) which accompanies the design process. That high level programming invironment should allow advanced algebraic operation, generation of equation-defined curves, surfaces, volumes, generation of tables, refferencing and assignment of feature and sketch parameters and other document properties. One may say that Feature Script allows something from what was described, but for me it is a bit complicated and saturated syntactic peculiarities.
  • thomas_miglincithomas_miglinci Member Posts: 34 ✭✭✭
    I would also like to have a way of easy editing/adding of variables - the available dialog is okay for a small amount, but if you are going to have many variables it is a pain in the a...
  • brett_suttonbrett_sutton Member Posts: 43 ✭✭✭
    Adding a variable whilst in a sketch would also be rather handy. I'm forever having to exit the sketch to add another variable. Given that sketches is where you use variables most often it seems like we should have the option here.
