MOTM April 2017 - Discussion Thread
This is the accompanying discussion thread for the April 2017 MOTM thread. Please keep any feedback, discussion, and questions related to the contest in this thread so that the contest thread will have only entries in it.
The contest thread can be found here:
https://forum.onshape.com/discussion/6156/motm-april-2017-contest-thread#latest
I would please ask that this thread is made a sticky, along with the contest thread itself.
1
Maybe I should state an actual prize amount, that might perk some people up
I have the tendency to play around quite a lot and make a mess, my feature trees are just cluttered with trial-and-mostly-errors.
Digital one would be interesting...may have to be an odometer style.. (hint hint)
I got idea for next month, you could post motm as a question (Do you have nice models?) and mark contest model posts as answers - that makes them stick first in line; then we could use same post for discussion which might keep it at least first page of forum..
And reward for posting is getting 'forum points' for answer and for up votes you might get
On a side note, I have been contacted by Onshape staff since the posting of the "contest" to see if there may be some better way that this could be done...there exists a possibility that in the future we could hold the contest in the appropriate MOTW forum, possibly with poll functionality. Stay tuned.
Luckily it's really early. I will add something from me to keep the contest alive.
projektowanieproduktow.wordpress.com
Thickening curved bottom should fail, due to inevitable gaps between patches, but to my surprise, it did not.
Again apologies.
Though it doesn't necessarily generate a model, I'll submit my non-uniform scale feature sometime soon in that case, quite happy with it. It's useful in some cases at least.
Once this MTOM catches on, it'd be pretty neat to introduce a Script of the Month contest as well.
FSOTM needs pretty detailed description and real world examples to stand up - posting piece of brilliant code doesn't open to everyone
I would like to know what is the need/problem it solves and see some example on that use case.
FSOTM would definitely be a good thing, from my point of view FS really is the Onshape's strongest point right now anyways (I don't do much with sheet modelling personally, for example).
Sometimes I'm a bit annoyed cad forum being filled with FS code stuff that 99% (?) of user don't understand. I wouldn't mind if FS posts were not in latest list but only appear to separate section (like it was in the beginning of FS)
oops.. wen't a bit off topic, but felt good to spit it out
That doesn't mean I don't think that many things which are now only doable with FS should become standard.
Now let's get back on topic
I'm perfectly OK with FS being counted as submissions, and I'm pretty sure I had mentioned that in the contest "rules."
Again, this first month should be treated as a trial run. If the demand is such that a separate contest for FS seems logical, then we'll do exactly that. I have hopes that by next month I may have further capabilities on the forum such that I might post the contests in a format that allow polls, and perhaps in a different section of the forum.
I can understand that those tools perhaps fit in another category, as they don't provide any model themselves, which is why I asked
Excited to see more submissions!
That being said
I am very anal, and take good care of my precision equipment
Cool I see you got your Syncro drives all working
Good job
On a seperate note, I need feedback from people as quickly as possible to avoid delaying things too much...I'll gladly start another month's contest, but only if there is enough continuing interest.
Also, any suggestions for a change in format or rules will taken into consideration.
I have a few more models to submit as well
You could try to make next post as question and mark contest posts as answers so they stick on the top and have conversation on same post to keep it on top of discussions.
