Modeling internal O-Ring Groove
bill_danielsbill_daniels Member Posts: 282 ✭✭✭
If this were a cylindrical part, I would use the rotate feature but it's a block with a large number of holes each requiring an internal O-Ring groove.  At the moment all I can think of is to model a "tool" in the form of a disk and then use Boolean subtract which seems fussy.  Is there a easier way to do this?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,043 PRO
    edited April 2017
    Do you want a fake groove or a dovetail ?
    Either way I would use the sweep tool and sweep along the path you want
    On second thought... Is this groove on the flat face or the internal hole ?
    edited April 2017
    I think a tool body with boolean is one of the best solutions, you can position it with transform and all the geometry will have one source to modify. only custom feature script might be better
    @konstantin_shiriazdanov 's right, feature script may be best if it's the internal o-rings
    I haven't used this but it appears to be what you are looking for
    https://cad.onshape.com/documents/58d064383d98a90f86ea0a03/w/3271372ad9fdffb291eb4d91/e/913be26cf5ef20ae413c7c38
  • bill_danielsbill_daniels Member Posts: 282 ✭✭✭
    John McClary - Its an internal O-Ring groove.  The O-Ring Feature Script is cool - thanks - and I'll use it for placing O-rings but it doesn't create the groove.
    Ok good to know, It looked like it did in the description :(
    I suppose creating a groove is similar task that creating an o-ring. Why not add it into feature..?
    Otherwise, +1 for tool & boolean
