Ability to create helix spring with spring eyes
andreas_scholzandreas_scholz Member Posts: 14
I tried to create a helix spring with spring eyes one each end. Helix creation is no problem. Spring eyes I defined with a sketch and used composite curve to have a single guide curve for the sweep. I miss the functionality to add a 3D-corner with defined radius. Spring does not look fine at the moment.
