Ability to create helix spring with spring eyes
andreas_scholz
Member Posts: 14 ✭
I tried to create a helix spring with spring eyes one each end. Helix creation is no problem. Spring eyes I defined with a sketch and used composite curve to have a single guide curve for the sweep. I miss the functionality to add a 3D-corner with defined radius. Spring does not look fine at the moment.
the possibility to add 3D-corners is not limited to create helix springs. This was the actual problem I had. It would also be useful to add 3D-corners between any other curves that intersect or are connected. Perhaps FeatureScript would be a solution as well. But I am not familiar to programming.
https://cad.onshape.com/documents/c069ddefb6e8bbe1de68bec0/w/e5545c1c8009fef5a7cee3a4/e/4e1018563d5e889f70f49ee5
https://cad.onshape.com/documents/d6b22bb18dc3cfb687298460/w/6703ddb0819f93dab96a32d2/e/5107e20a58183eeda2f2a5d0
https://cad.onshape.com/documents/cdae3a1f009f41e8b5dd7e9f/w/96a0850e944040979fd806e6/e/02d0b2e6e5f14132a6678321
