Countersink head size for M4.5 is not correct
Fox66
Member Posts: 4 ✭
I think the numbers provided by the hole wizard are not correct for Countersink ISO Clearance M4.5
Close clearance M4: hole=4.3 head=8.96
Close clearance M4.5: hole=4.8 head=4.8 <--Head size: 7.5?
Close clearance M5: hole=5.3 head=11.2
Normal clearance M4: hole=4.5 head=8.96
Normal clearance M4.5: hole=5 head=5 <--Head size: 7.5?
Normal clearance M5: hole=5.5 head=11.2
Loose clearance M4: hole=4.8 head=8.96
Loose clearance M4.5: hole=5.3 head=5.3 <--Head size: 7.5?
Loose clearance M5: hole=5.8 head=11.2
The tapped and drilled numbers are also wrong.
owen_sparks Member, Developers Posts: 2,660 PROHi @pete_yodis thanks for the information, and all the effort thrown into improving an already good product.
I appreciate the situation but must must say in my opinion it's not the approach I'd wish for. It may be clear to the user on creating a feature if it doesn't work, but what if we look at our working M5 feature and decide to change it to M4.5? The hole feature completes without any indication that it's not made what was asked for. It might be missed that it failed and get released into production.
If a feature is released it either needs to work, or at the very least shout about anything that doesn't. The shouting should be big and red and in the middle of the screen, not the tiny little blue banners in the header.
Just my thoughts.
Cheers, Owen S.
HWM-Water Ltd5
As an example I've just checked and the updated hole command is still bugged as above. An M4.5 countersunk hole gives a 5mm countersink which is actually the clearance hole size so gives no countersink at all.
I've not known OS release anything incorrect before, so would have thought it would have been jumped on if they're aware of it. Making incorrect holes is worse than it not working at all after all.
Cheers, Owen S.
No worries, OS has built up a pretty hefty bag of good-will so this won't dent it!
If on the other hand you'd care to throw us an extra year's pro subscription for an additional user as a finder's fee I'd not argue
In the future we plan on allowing a fastener type selection after the counterbore and countersunk hole type (along with a recess parameter to ensure the fastener type is to be recessed below the face). This really provides a far greater level of support in the hole feature than what you see today. I hope users understand. We're working to make this a far better area of the product.
Just my thoughts.
Cheers, Owen S.
