Improvements to Onshape - July 25th, 2017
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
Here we are again, ready for another update for you. A big focus for this update was improvements to drawings and there are many. We hope you like them!
DIMENSION IMPROVEMENTS
The Dimension command in Onshape Drawings can now be used to create nearly any dimension. You no longer have to pre-select the correct dimension command from the toolbar.
PARTIAL SECTION VIEWS
You can now create Partial Section Views in Onshape Drawings.
EXPORT DRAWING DOWNLOAD OPTIONS
You can now export a drawing or sketch and store it as a tab in the Document. This is especially important for creating Drawing Templates. In the past, you had to export a template file and then import it into a Document. This new option eliminates that.
WELD SYMBOL IMPROVEMENTS
New support for Spot and Seam welds as well as a Drawings Properties option that allows you to specify which standard you want your weld symbols to conform to.
DRAWING VIEW NAMES
You can now give a drawing view a name. In the view properties you will see a new option for name.
FLIP SKETCH TEXT
There is a new option in the Sketch Text command to "Flip vertical" and "Flip Horizontal." These will allow you to flip the text you are creating. Also new is a preview window in the dialog that allows you to see a preview of the text before accepting.
Please take a moment to try out these new features and improvements and let us know what you think!
DRAWING VIEW NAMES
FLIP SKETCH TEXT
6
Smart dimensions, Export drawings to tab within OS, Drawing Name Views, and ISO Weld symbols.
Great improvements.
https://youtu.be/X7HmltUWXgs?t=33s
UX/PD/Community Support
Correct me if I'm wrong but isn't that View Label, not view name?
OS drawings are really beginning to come into their own with these improvements. Thank you especially for the 'export as new tab' improvement.
Keep up the exceptional work!
Templates...download to tab - very nice.
I'm kind of glad I'm a little behind on drawings, now I can try this stuff out.
Linked[in]
CJH Onshape Drawing Critique 02Aug17
I have been holding off on updating my ISO 3rd Angle drawing templates, awaiting further improvements from OS. The recent ability to amend templates within OS is a welcome improvement, along with property links to various fields.
This morning I trialled amending one of my templates, and decided to hold off improving my templates until the following enhancements are made:
1. Date formats are currently restricted to USA date formats (there is no provision for other formats that I use such as 02Aug2017 or 02Aug17). In Australia, 08/02/2017 is read as 08Feb2017.
2. Mass properties are still not available as a linked property.
3. Custom materials are still not available.
I agree, we have dd.mm.yyyy standard in Finland but I always use yyyy-mm-dd for consistency and best sort. If I was the king of everything, I would deny all the others
for global date standard
Already use it to file emails
Sad thing is... even the project's I've released with OS, I still have to export->import->export to eDrawings then file...
I'm just surprised some people at work don't still have an AOL account..
What you have demonstrated is exactly what I am seeking in relation to date format. However, the date format drop-down is currently "greyed out", so I am guessing that this is in the queue for release?
Also can someone demonstrate to me how to reply correctly with the format @personsname? I am not a Twitter User.
Regards
chrisjh777
