How can I include a variable value in a sketch text?
jon_woellhaf
Member Posts: 92 ✭✭✭
I have a spur gear generator. How can I label each gear with the number of teeth in the variable #Teeth?
11
It would also be great to link back to the properties or the parts name as well, especially when adding parts numbers to a part.
We do not give an ETA for anything in development.
You can vote on this improvement request to help us prioritize this task:
https://forum.onshape.com/discussion/3796/variable-values-displayed-in-text
What about the support tickets we sent?
should we add all our support tickets (the ones that were marked as an improvement request) to the improvement request list?
Support tickets and improvement requests are actually treated the same way once they get to the developer, so if you make a support ticket that gets marked as an improvement request, you don't need to worry about posting in the forum. Generally I would say that you should use a support ticket if you have something that seems like a bug/problem with existing functionality, and use the 'Improvement Requests' section of the forum if you would like to request new functionality that does not already exist in Onshape.
But if you priorizate the improvement request based on the number of votes of the users...
The support ticket marked as an improvement request will only have "1 vote".
Should we add these existing support tickets (marked as an improvement request) to the list so users could vote for these and priorizate their development?
UX/PD/Community Support
