merge one part studio
svenolov_nystromsvenolov_nystrom OS Professional Posts: 84 PRO
Is there any simple way to merge only one single part studio to another branch ?  as I can see it I ll have to make a version and delete all other parts and asm and merge. And then make a new branch from the created version.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,996 PRO
    Branching and Versions apply to the entire document. You will need to use your work around.
  • raj_Onshaperaj_Onshape Onshape Employees Posts: 111 image
    If that part studio is being used in an assembly or another part studio as a derived feature, What is your expectation of merging only the part studio ?
  • svenolov_nystromsvenolov_nystrom OS Professional Posts: 84 PRO
    I had made some work in the branch part studio and wanted to save it to the main and not merging the hole branch.. I have learned to be careful with merge its easy to make mistakes I have done a lot of it.
    If that part studio doesn't have a lot of strings attached, why not just copy & paste?
