Configurations and Colors / Material
john_mcclary
Member, Developers Posts: 3,890 PRO
Anyone know a way to configure colors and material?
I want to be able to show the different part as a separate color because the parts look very similar.
material is a bonus at this point, but I'm sure it will be the same solution as color.
john_mcclary Member, Developers Posts: 3,890 PROYea I went through that area, didn't see "Appearance" there.
Thanks0 -
ilya_baran Onshape Employees, Developers, HDM Posts: 1,173It's there under "Add property"Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc6
ilya_baran Onshape Employees, Developers, HDM Posts: 1,173Yeah, I figured you found it, I was just clarifying in case someone else reads the threadIlya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
Jason_S Moderator, Onshape Employees, Developers Posts: 210@mbartlett21
Regarding the drawing issue:
When making a drawing right now the sheet reference is set at the configuration that the sheet was created at and you cannot change it without fiddling with the sheet reference. This issue is known, is already fixed and will be available be in the next release.Support & QA6 -
owen_sparks Member, Developers Posts: 2,660 PRO@Brandon_Chiou
Did you see this post?
https://forum.onshape.com/discussion/8605/configuring-part-property-problem-now-fixed
Regards,
Owen Sparks.
HWM-Water Ltd7
I did not see this right away either -
Thanks
I didn't see appearance the first time i checked before posting the intitial question. I was looking for 'color' instead
In all seriousness that is very well done. I love that any company custom properties appear in the "configurable" list, that's outstanding.
Can I assume that at some time in the future we'll be able to configure one property based upon the value of another another? (Say I have a custom property of "Production Line", and then want to automatically set the appearance based on that rather than an explicit value in a table?)
Cheers,
The colors and part names do not update in assemblies to match what is in the part studio
Please file a ticket and we'll take a look.
I have to right click, then select sheet properties and say that that part is the reference part.
When will it be released?
Also, when I go into sheet properties, the only reference I can update the reference to has the name from the old configuration.
In context:
I am looking to add color as a configuration input to avoid manually assigning specific colors to permutations of these two sets. Am I missing something here?
Thanks!
Regards,
Owen Sparks.
With test two I simply created a stupid list which shows all possibilities. So that the columns are described properly I rebuilt the model tree. (see picture V2_B1)
Is this the only way or can Onshape do it smarter?
Friendly greetings
V1_B1
V1_B2
V2_B1
V2_B2
I made a Part Name feature (pretty much borrowing and building on Part Number by @NeilCooke). I also made Part Color. With these two, you can add any name or color info to the main configurations tables instead of having to configure every possible permutation for the properties. in the Part Name document there's an example part studio that's configured with an example. I think it should solve your problem.
Website: ovyl.io
Thank you @Evan_Reese
Your solution will work.
However, I encountered another problem. Not all lengths are available in all diameters. This means that you would have to define a max. and min. length per diameter. I do not want to make the component unnecessarily complicated. It should be easy to use for every employee in the company. And if it is to be extended by a variant, all employees must simply understand how the configurations are built up. I think I'll stick with the simple (silly) list for now. This is comprehensible and expandable for everyone.
I wonder if there are posts in this forum on the subject:
How to build a simple parts library for a company in Onshape?
If not i would like to open the topic in a separate thread.
Greetings
It definitely becomes tough when you have a configuration variable that might allow options that don't exist. For now, I think just a big list is the way to go, unfortunately. Eventually it would be awesome if the devs made a way to do more complex configuration setups that might allow for a lookup table which would solve your problem too. (Lookup tables are how the hole feature is made so you can only find metric hardware once you pick ISO, etc). I've made a hardware library for our company, Ovyl, which I intend to make a whole video about at some point. For now, I do talk a bit about it in my Featurescript Variables tutorial, and at least that part might be useful to you. Check it out: https://www.youtube.com/watch?v=uB43P7LqkHw&lc=UgxvFYRmjgBQfudnoe14AaABAg.9Rm6oC-ZCsa9Rp7-UKvR7i
Website: ovyl.io
