Mate Connectors in sketches
MBartlett21
Member, OS Professional, Developers Posts: 2,034 EDU
Is there any way to have a mate connector owned by a sketch except in assemblies
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,443No, it has to be a solid part. I agree it should be possible so please kindly create an improvement request.Senior Director, Technical Services, EMEAI6
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,443You can mate to the assembly origin while adding a mate - admittedly it's not easy, but it can be done.Senior Director, Technical Services, EMEAI6
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭can hardly understand what is the reason for origin point in assembly, because you can't actually do anything with it. if there was mate connector in the origin by default it would be much more useful
6 -
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381@mbartlett21 - it's actually easier than Neil is making it out to be - he has farmer hands with fingers like carrots
To orient the mate connector wrt any default plane is really easy;- Select the mate connector tool
- Move the cursor to the origin
- You will see a preview of the mate connector and three gray lines emanating from the origin
- Moving your cursor from gray line to gray line orients the primary (blue) axis with the gray line under the cursor
- Click when the mate connector is correctly oriented
BOOM!Philip Thomas - Onshape1 -
Optionsrobert_morris OS Professional, Developers Posts: 167 PROThere is a mate connector at the origin, it's just not visible by default. If you hover over the origin while in the mate dialog, it will show up. Moving your mouse closer to one axis or another will let you switch which "side" it will mate to (top, bottom, right).
Here is an example of mating a part to one side of the origin with a 20mm offset.
You can see as I hover over the origin, the blue axis changes. The blue axis of the mate connectors are the primary axis that get aligned together.
3 -
Optionsmichael_mcclain Member Posts: 198 PROI wish I could invite that response more than once! How have I not known of that mate connector!?!?5
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,443Senior Director, Technical Services, EMEAI7
Optionsbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,137 PROkonstantin_shiriazdanov said:can hardly understand what is the reason for origin point in assembly, because you can't actually do anything with it. if there was mate connector in the origin by default it would be much more useful5
Here's the improvement request: https://forum.onshape.com/discussion/8162/mate-connectors-in-sketches/p1?new=1
I also think it should be possible to mate to planes in assemblies, especially the right plane.
As of now, the only way to do that is to create a mate connector on the origin in the part studio, assign it to a part that's been modelled in the correct position, import it into the assembly, fix it, then you have a mate connector to mate to.
How would i get it facing to the right or front or whatever??
Could you give me an exaple of how this could be done in an onshape assembly please?
-Morgan
BOOM!
Thanks for the information
