Pin/Slot Mate Examples
lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,011
edited August 2014 in Using Onshape
In the help documentation we show how to add a pin/slot mate in Onshape, however the example shows how it works when there is a blind slot.
https://cad.onshape.com/help/#pinslotmate.htm
If your pin/slot interface has a through slot which does not have a "floor" to it, here is how you can get this to solve. Simply follow all the same steps but hover over the top face the slot is cut through and while holding SHIFT, pick one of the mate connctors on the radius of the slot.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,092 PRO
    I'm not a pinslot expert, but I think you have to pick the rotating mate connector 1st and translation 2nd.
    I couldn't get them to work properly until I adopted this. Lou might be able to confirm this.
    Good point @bill ! This is the case. We are looking at adding a better UI for understanding the selections are FIRST: Pin, SECOND slot...
  • dan_engererdan_engerer Member Posts: 63 PRO
    Hi everyone. Whenever I try pinslot, it seems like a 50/50 chance that the pin will move perpendicular to the slot, even if I do everything else mentioned in this thread. Any ideas?
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,056 ✭✭✭✭✭
    If it does, you can click the "rotate secondary axis button" (the one that is four circles in a diamond pattern with an arrow)
