WebGL not enabled - message on Vivaldi 1.13 Linux
Please try loading https://cad.onshape.com/check. That page runs a few tests for Onshape browser compatibility.
I've also installed the latest stable 1.13 64 bit vivaldi release (1.13.1008.44) on Linux (Ubuntu 14.04 LTS 5), and am able to open Onshape documents. If the browser check page looks OK, are there any errors in the vivaldi console?
Regards,
John de Freitas
That page is fairly negative
A few questions :
- What exactly do you see, when you open an Onshape document? Can you post a screen shot?
- Have you checked out some of the troubleshooting steps described here: https://cad.onshape.com/help/Content/webgl.htm
- Do you see any error messages in the Chrome debug console?
- What graphics card do you have? Are the drivers up to date?
- As a test can you try opening this WebGL heavy page : https://threejs.org/examples/#webgl_materials_cars ?
Thanks
Paul
I cant seem to force it back to that initial "attempting to work" view, I guess its somehow stores the "not working" flag - tried deleting all the cookies and local storage etc, no dice.
I can see shiny spinning cars on the thereejs.org page.
I think Im using the AMD onboard graphics device.. no idea re drivers
Woo! I turned on Override software rendering list in vivaldi://flags.. and now it seems to be working!
Will see how it goes.. (I wonder what vivaldi changed.. or maybe the underlying chromium did..)
I tried changing the settings in account/preferences - no difference.
Mouse gestures not turned on in browser at all.. odd.
With regards to the mouse gestures, do other browsers have the same issue as well. If this is Vivaldi only, can you try disabling the mouse gestures and then try Onshape?
Can you also check in the Vivaldi forums to see if they have any suggestions?
Meanwhile, tried google-chrome again.. it seems to be fully functioning at the moment - without messing with its settings/flags, it both doesnt complain about webgl, and the mouse works..
such fun..
Installed vivaldi 1.9 snapshot just see if that would work.. nope - same webgl issue.. and flags page doesn't load..
however.. actual document pages look the same as before
and the onshape webgl check page is back to red Xs.. is it possible that starting onshape causes my browser to turn off hardware acceleration?
I managed to capture what things look like just before onshape gives up:
Owen S,
how come you've got about 65 tabs open??
Does that improve performance?
.. and its not, quite.. I have a Tab Suspender installed..
