SHEET METAL
Jeremiah
Member Posts: 1 ✭
I Love what Onshape is doing, I will definitely need the sheet metal option.
18
I already could do a lot with a base flange, edge flanges and unfold.
Dries
Usually, sheet metal uses same algorythm as features that modify solid bodies, like twist and bend. As they are not yet implemented, it might take a while to get these new features.
CAD Engineering Manager
+ ∞ for drawings :-)
Twitter: @BryanLAGdesign
This was a real pain. But it can be done. I'm asking for a trimmed surface from a sketch (basically an extrude with no thickness). With this I can quickly layout a sheet metal part and then thicken the surface into what you see. Turns out I do the same thing in SW even though I have all those fancy sheet metal icons. I think sheet metal as surfaces and then thicken is faster and more robust than the traditional sheet metal features.
I figure this will get shot down, but just think about it.
I unfolded this in SW, I would like unfolding added to OS. And while you're in there adding unfold, create a surface flatten tool also. SW should have been able to flatten a surface.
