Entities selection priority
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
Recently i notices that some of my FS and standart features suddenly started to only allow Entities of body type if the input field filter has this option among other entity types like faces. This is exactly not how it worked before, and i liked prevous behavior better. Was this intentional global change or it only with me?
In the meantime, you can use the "Select other" command to select individual entities.
Releases come approximately every three weeks.
That will mean I can remove some selection boxes in my feature here.
projektowanieproduktow.wordpress.com
what i think the code should look like:
For the upcoming release, we are simply reverting back to the old behavior for all custom features, so the issues described here will be fixed. However, if/when we want FS writers to control this, we'll use an explicit UIHint rather than implicitly encoding the priority via filter order.
