offset in bidirection in Sketch
zhifei_ge717
Member Posts: 4 PRO
in Drawings
I want to offset the figure in both directions by 0.01 and form, but Onshape always says "Could not offset entities"
It's very straightforward in SolidWorks. Did Onshape change this?
1
@NeilCooke he means it offsets to both sides of the line in one click of the offset command. Much like the slot function without capped ends.
LearnOnshape facebook group
Maybe you'll like the "Slot" function?
https://cad.onshape.com/help/Content/sketch-tools-slot.htm
@NeilCooke is there in 2026 no bi-directional offset possible in onshape? it would be a very interesting thing to be able to do - that and to be able to make sketch dimensions equal to another without creating a variable "on the fly".. when do these kind of updates get done? 2018 was a while ago…
I needed this, but in my case a simple extrude did the job because I picked the "thin" option that only extrudes a wall shaped like your perimeter, not the whole face. After that it should be possible to project the face of the created solid back into a sketch.
