Use Chamfer and Fillet together
john_mcclary
Member, Developers Posts: 3,898 PRO
Why is this a even an error?
I mean, it isn't impossible geometry, I just am forced to go back and delete chamfers and re-draw them as extruded cuts instead...
With the mates it is possible to edit an existing mate to change the type, say from fixed to revolute without having to delete and start over.
Perhaps as the chamfer and fillet functions are so similar they could be combined so you can swap a chamfer to a fillet in a drop down?
Owen S
What you are asking for is different, and is available in Solidworks as a matter of fact, although I haven't used it yet.
Through further experiments, it appears this only occurs in sheet-metal (you know the type of geometry that would normally get a fillet on every sharp corner)
