offset in bidirection in Sketch
zhifei_ge717zhifei_ge717 Member Posts: 4 PRO
I want to  offset the figure in both directions by 0.01 and form, but Onshape always says "Could not offset entities"
It's very straightforward in SolidWorks. Did Onshape change this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,973 image
    Please share the url to your doc.
    Hi - you would have to make the doc public for me to copy it (that is a read-only link). Anyway, I recreated it and the issue is that you are going from a closed region (that is 2D) to a single line (that is 1D). If you made it in two sections (top and bottom) then you could join both ends afterwards. Would SW really offset the whole profile?
    No bi directional offset is not there yet. I have wanted this for quite a while. You can use the slot function (dropdown arrow beside the offset brings this up) and then go an delete the capped ends. This is a kludgey workaround but with the right amount of lines it works out to slightly less mouse clicks.
     @NeilCooke he means it offsets to both sides of the line in one click of the offset command. Much like the slot function without capped ends.
  • zhifei_ge717zhifei_ge717 Member Posts: 4 PRO
    Thanks for your comments. I think I got what's possible with Onshape. I was expecting the bi-directional offset like that in SW, which allows me to draw centerlines of a slot network and bi-directionally expand .
  • derek_wardderek_ward Member Posts: 73 EDU
    Jake, a slot will work in instances that are simply a straight line, however, if you wan multiple connected lines or a circle you are out of luck.  A bi-directional offset is needed.
  • Andrew_GunstoneAndrew_Gunstone Member Posts: 3
    @NeilCooke is there in 2026 no bi-directional offset possible in onshape? it would be a very interesting thing to be able to do - that and to be able to make sketch dimensions equal to another without creating a variable "on the fly".. when do these kind of updates get done? 2018 was a while ago…
  • a_bva_bv Member Posts: 1
    edited February 17
    I needed this, but in my case a simple extrude did the job because I picked the "thin" option that only extrudes a wall shaped like your perimeter, not the whole face. After that it should be possible to project the face of the created solid back into a sketch.
