Can I create a new Document from a Part Studio.
I created a Part Studio in a Document and I want to use it in other Documents or share just that Part Studio with the Public but not my entire Document.
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
You can use RMB menu for part studio tab and select 'Copy to clipboard' and paste into another Document.
It will be a copy and not associating if original part is changed.
Sharing covers the whole document, but if you create another document where you paste the part studio and make it public - it has no affect on your 5 free active documents.//rami5 -
Sorry, forgot to mention about pasting. I think browser hijacks ctrl+ x, c and v so they can't be used in Onshape special functions.//rami5 -
I think @BruceBartlett has made some collection of standard bolts & washers for public.. I'm not 100% sure though, try search.
//rami5 -
moengineering Member Posts: 23 ✭
3dcad said:I think @BruceBartlett has made some collection of standard bolts & washers for public.. I'm not 100% sure though, try search.
here is the document:
https://cad.onshape.com/documents/516b1784884d4facbc4c0d74/w/8e947edb43904354bb16b3f2/e/c23d6f9b205c442db6579475
Best regards
Martin5 -
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
Bill H said:My intent was to start a Document which would contain frequently used parts, things like screws, washers, nuts, etc. When I downloaded a split lock washer from McMaster-Carr I wasn't able to get and axis mate connector because of the way it was made and translated into my document.
I started mine because I thought it would be good to have all part built natively. I have not finished the complete series just the series I need at the time. Things may change so not putting too much effort in. Its public so your welcome to copy tabs out,
I do love how the lists fill out when you create an assembly after you have dropped one of these part studio's into your doc.5
Best regards
Martin
Thanks for the bolt reference book,
@andrew_troup Metric is the only way to go. However I still have to use imperial bolts every now then.
If people are using the fastsners I doc might have to do some more work to improve it.
Bruce
as @BruceBartlett says, he is the Austrailian and the boltz and nutz document is from him. I just linked them. By the way: I am the Austrian. There are also cows but no kangaroos
But there are things in common: I also work metric and I am thrilled with onshape too.
best regards
martin
@BruceBartlett is there a special reason why you made all nutz and bolts at the same position in the parts studio?
best regards
martin
Originally I wanted the 0,0,0 point too be under the head, but with the mate connector system this proberly doesn't mater. Still a work in progress.
Bruce
Thats the way I also would have done it before OnShape. Because in all other systems you should take care of that. Here it doesn't matter. Thats pretty cool
best regards
martin
