3D Connexion mouse not working
in General
I've got a new machine, and so far have not been able to get the 3D Connexion Spacemouse wireless to work in Firefox other than zoom in Onshape. In Chrome, it initially worked with full control, but now is only doing zoom also. I've verified with the viewer that 3D Connexion supplies that it's working properly in that. And I've got all the checkboxes checked for the types of motion for it to control, and the settings dialog is recognizing that Onshape is open (it's not seeing a generic Chrome instance for example). I tried uninstalling and reinstalling, but no change. Am using the latest Windows 10 64-bit driver, 10.5.4.
Any ideas?
Any ideas?
- Check if the 3DXNlserver is running in the task manager
- Can this page be openened: https://127.51.68.120:8181/version- Which server version is being displayed?
- If the page does not open you should disable the Firewall.
- Check again if Onshape works with FW disabled.
It seems 3dconnexion driver connects to their web server to control Onshape. Whenever I'm in the network with limited access (e.g. at customer with strict firewall rules) then the control in Onshape is limited to move and zoom.
/Krz
I investigated @krz's advice and report the following:
- Check if the 3DXNlserver is running in the task manager. (Yes, can be found under "more details" within Task Manager)
- Can this page be openened: https://127.51.68.120:8181/version (No, but if I restart the computer with the IP address still active in a browser tab, the version 1.2.3.14519 appears)- Which server version is being displayed? (3DXNIserver Version 1.2.17291.14519)
- If the page does not open you should disable the Firewall. (Tried this, but still no go, even after reboot)
- Check again if Onshape works with FW disabled. (Tried this, but still no go, even after reboot)
Fusion 360 works fine with the USB 3DConnection mouse at all times. Solidworks 2015 SP5 behaves just the same as Onshape, that is, useless.
I have a second computer with a wireless 3DConnexion Mouse that works fine with all 3 programs, Onshape, Fusion 360, and Solidworks 2015.
I have reported the issue with 3DConnexion in Europe (seems Australia does not exist in the eyes of 3DConnexion, and Europe is the default support location for Australia), but to date they have not responded.
I have always kept 3DConnexion software up to date, maybe that is the problem.
The frustrating thing is that it worked fine for years, .
- Yes, 3DxNIServer is running in taksmanager. It shows it as 32 bit, even though I downloaded the 64 bit version of the software.
- Yes, can access that url, the server version shown is Server version: 1.2.3.14519
I'm on Firefox 57. My Chrome is Version 63.0.3239.132
I tried again with Chrome and it was doing the same thing, zoom only. I went into the settings to get the version number (in a new tab), and then came back to the Onshape tab and now the 3D mouse is working properly. And now I go back to Firefox and it's working there too after not working 2 mins ago. Very weird... So I'm not sure what's enabling/disabling it.
And as @adam_richardson wrote: SE works in Chrome but not in Firefox alone. If I start Onshape in Chrome then SE works in Onshape in Firefox too. What's going on here? It seems like Firefox blocks some communication to ... where? onshape or 3dconnexion server?
I "added another app" in Control Panel\All Control Panel Items\Windows Defender Firewall\Allowed apps:
C:\Program Files (x86)\3Dconnexion\3DxWare\3DxNLServer\bin\3dxnlserver.exe
Then it worked. Windows 10 Version 1709 OS Build 16299.248
Problems started when I updated from some much older driver (unknown version) to 10.5.4 in December and it mostly worked, but I had to click out of window and then back into window a couple times every time I toggled from and to my Onshape window.
This week the driver wouldn't work at all. No amount of restarting or tinkering would make the 3Dconnexion driver start. I went out and got the latest version and updated to 10.5.5.
This worked flawlessly for about a week before suddenly I got a Windows warning that 3dxnlserver.exe had crashed. After this the driver still worked fine and I could run 3Dconnexion demos and such, but Onshape wouldn't work at all with it. Restarting and manually running 3dxnlserver.exe did nothing, so I reinstalled. Nothing. I uninstalled and loaded older drivers to no avail. I installed the latest driver again and now Onshape works with my Spacepilot Pro but only if I run it in Chrome... The Firefox version won't work at all.
This is pretty bizarre and I'm really not sure what to do short of reinstalling Windows. Clearly something got hosed somewhere deep in the registry or something.
I tried the following steps and it seems to work. If you are using Chrome.
1. Close Chrome
2. Stop the 3Dconnexion driver
3. Start the driver
4. Start Chrome and Onshape
Best Regards,
Since I use FF exclusively for Onshape and Chrome for browsing, I'm not so worried about the security loss of not upgrading FF for now, so I'll stick with that.
I have a temporary fix, working consistently for me, documented in the other thread. See Post 145 in this thread: https://forum.onshape.com/discussion/8449/3d-connextion-space-mouse#latest
https://www.3dconnexion.com/service/drivers
They are still working on an updated release for Mac. If you would like to use newer Firefox on the Mac, you can get your Spacemouse working again by manually adding 3DConnexion's certificate in Firefox preferences:
We're following up on this thread to let you know that we are aware of the issues affecting our customers, users of Onshape in Mozilla Firefox for macOS.
Although we have addressed the issue discussed here, we have had to delay the release due to unexpected quality issues. We're now targeting a release towards the end of June. This will be v. 10.5.3 of 3DxWare 10 for macOS.
We're sorry for the delay. It's a disappointment to be taking this long to address a problem such as this.
It includes support for recent versions of Mozilla Firefox, resolving the issue with the certificate installation.
Again, we're sorry for the delay in addressing this issue and we're thankful for Onshape's assistance in getting this problem resolved.
There is always the ol’ Uninstall 3D connexion and reinstall the software.
Wish i had some magic fix for you but your among friends with this issue I’m afraid.
