Drawings not loading
yuval_taffyuval_taff Member Posts: 17 PRO
Hey, I am having a really difficult time creating drawings of my assembly..which really isn't super complex.  I try to place a view on the drawing sheet, it appears to be loading for a good few minutes and then it crashes and I get an error notification. Yesterday it was working, however once I placed the view on the sheet, I selected to show hidden lines and the same story..loading for a few minutes and then an error message.  Whats the story? Thanks
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 234
    Hi @yuval_taff, Sorry for the difficulties you are facing. Please contact support using the Help Menu (?) -> Feedback option. Support will be able to look at the issue.
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,062 ✭✭✭✭✭
    @yuval_taff
    Does hiding tangent edges help?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,962 PRO
    hidden lines will slow your drawing down significantly. (unfortunatly)
    So try not to turn them on unless you really need them. (I know it is a crappy thing to say)
    look at the difference in performance here: https://youtu.be/3sghldOD8v4
    @john_mcclary
    About my post before, should I make an Improvement request for tangent edges hidden by default?
    @john_mcclary
    To be honest I always show tangent lines. But there is a guy I work with who wholy disagrees. (Then he wonders why people machine his channel iron parts upside down hehe)
    So if it is a checkbox on your profile I could agree. But it would need to be a checkbox in the company profile too, that overrides the user's setting.
  • yuval_taffyuval_taff Member Posts: 17 PRO
    Hi Paul,
    We shared the file with Onshape and it seems someone named Lou Gallo had a look at our document.  We aren't able to see any of his comments - where could we find those? Also, in reference to our drawing requirements, we need hidden lines so unfortunately we aren't able to simply remove those.  Drawing seems to work albeit still very slowly..any recommendations would be greatly appreciated! Thanks in advance
    Hi @yuval_taff
    You can see your currently open support tickets by following the instructions here:
    https://www.onshape.com/support
    From the "View support tickets" page you can ask specific questions about the tickets you have open.  Looking into the tickets you have, it looks like we never heard back from you about the document you were concerned about.  It may be easiest to just open a new ticket in the problem document, and make sure you check the "Share this document with Onshape Support" while you are submitting the ticket.
